Yamaha did not make the GP model until 97 and if the numbers you posted are correct you have a 94, that being said all yamahas up until 93 were either a 500 or a 650 so im guessing its not a superjet which is a standup so you may have a waverunner 3, Raider, Blaster, or a wave runner LX. What colors are on it? does it have twin carbs? there will also be a sticker on the engine cases noting engine size.
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
