ASUS P5LD2-VM Motherboard Logo
Posted on Nov 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a asus p5ld2-vm/s motherboard for which i want to buy a graphic card i dont know what type the board supports either agp or pci-x.can any one help me
Anonymous
Level 3:
  • Master 685 Answers
  • Posted on Nov 26, 2008
Anonymous
Master
Level 3:
Answers
685
Questions
Helped
229797
Points
1828
i have a asus p5ld2-vm/s - 01.gif Intel Graphics Media Accelerator 950
The new Intel Graphics engine has new capabilities that provide a significant increase in graphics performance. DirectX 9.0 hardware acceleration, 333MHz core clock, and up to 224MB of video memory all together provide a full-value, high performance graphic
Anonymous
Level 3:
  • Master 849 Answers
Anonymous
Master
Level 3:
Answers
849
Questions
0
Helped
315511
Points
2014
Yeah it has PCI Express is the latest I/O interconnect technology that will replace the existing PCI interface. With a bus bandwidth 4 times higher than that of AGP 8X interface, PCI Express x16 bus performs much better than AGP 8X in applications such as 3D gaming. PCI Express x1 also outperforms PCI interface with its exceptional high bandwidth up to 500MB/s.
Sound problem ASUS P5LD2-VM
The driver can be downloaded here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
Select your windows system 32 or 64 bit.
Click on audio and hit global for download.
Unzip the file before you install.
If the driver does not work buy a sound card to add in the pci slot.
Just make sure it supports your windows.
Good luck
13helpful
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
I am having motherboard P5SD2-VM motherboard having on board agp sis 3 mirage of 256 MB but it does not support to games like crazy taxi and even flash player programme which was working are not working...
Some games requires higher video card memory, you must look for the requirements for that game! I suggest if ur a GAMER, buy a HiGHER memory PCI video card! Taaah!
Which graphics card is best suitable for ASUS P5LD2-VM Motherboard
Not too shabby, looks like it will support PCI Express based cards since most these days are PCIe and PCI, so its personal preferance and what you can afford. But since its a Intel based board (according to reviews) nVidia is a logical solution, but ATi will still work fine
1helpful
INSTALLING GRAPHIC CARD 9500GT ON ASUS P5LD2-VM R1
First of all is this a new graphics card? If it is take the card out of the PCI Express slot, get a clean, dry, soft paintbrush and clean the PCI Express slot, then blow on the slot to remove any residual dust.
Make sure the brass contacts on the card are clean and then reinsert the card, make sure it clips into place properly and you secure the card with the screw at the back of the computer, then try booting the machine.
If you bought the card second hand then there is a possibility that the card is faulty.
Luckily for you i now a way to bring a dead graphics card back to life but you do it at your own risk.
Let me know how you get on and good luck.
Can i install pci video card in my p5pe-vm board ?
You could by why would you?  Even your " on board" graphics are faster that an PCI video card would be. You have a AGP 8 slot. Look for a really good AGP 8 video card. That should get you where you want to go. It will not be as fast as a PCIe16 card but you do not have that option nor slot of *********** board.
Below is the ASUS link to your board. http://www.asus.com/search.aspx?searchitem=1&searchkey=P5pe-vm
P4p800-vm pci slot is not recognising the add on card ( TV tuner)
There is no PCI-E slot on this motherboard. It has an AGP 8x slot and 3 PCI slots, but no PCI-E. Therefore, even if you could manage to get the PCI-E card physically into the slot it will never work.
Here is a link to the manual - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
1helpful
Graphic card slot for asus p5ld2-vm/s
PCI Express X 16.
Here is a link to the user guide for additional info:
P5LD2-VM Manual
See page 1-20
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
3answers
Compatible Graphics Card for ASUS P5LD2-VM SE Motherboard
Yes its compactable !! but u can onlt add 1 ;-)
he he...!
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
