Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
H400IDL gas pool heater won't start shows SF error code ran when closed pool won't when opening
Serial # 30312726 model H400IDL 400,000 BTU
    Top Expert:
  • Hayward Master
  • 10,383 Answers
Check pressure switch
Posted on Mar 19, 2016
6ya staff
SOURCE:
poolyoda
  • 128 Answers
SOURCE: same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Posted on Aug 23, 2009
Kieran Ruppert
  • 990 Answers
SOURCE: I'm getting an 'SF' error message on my H series
SF is a thermistor or hear sensor error. If the heater is not reseting it self after a few minutes then you may need to replace the sensor. Yes you probally can do this. On the left side of the water header their is a small tube like thing that slides into the header. It will have two wires comeing from it and you will follow these into the heater and around to the front panel. When they get to the circut board you just un plug them and string a new one in it's place. Good luck.
Posted on Jan 08, 2010
thepool
thepool
  • 78 Answers
SOURCE: Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
Posted on Apr 23, 2010
aquatechpool
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
Tom W
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars xl 400 heater off line
turn off aqualink then turn back on it should see it
Jan 25, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
AGS error code
check gas pressure if ok then see if runs 7 sec if shuts off then check flame sensor if blower doesn't start check safety circuit
Nov 24, 2012 | Jandy Lx Pool & Spa Heater - Electronic...
How do you replace a pool heater pressure sensor?
check pressure switch to see if voltage both sides if not see if copper tube is plugged make sure filters are clean
Sep 22, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
LX400 low pressure switch
if good water flow through heater make sure if you have a bypass it is closed half way if not check pressure switch to see if 24 volts on both wires if not bad pressure switch or clogged copper line to it
Jan 02, 2012 | Teledyne Laars Laars Lx Pool Heater /...
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
I have a Laars Lite 2 400,000 btu pool heater. It
It could be that the Igniter has gone bad. Or it cold be a number of other items, like the gas valve itself. If the heater has a display panel on it, is there an error code showing? If there is, go to your Owner's Manual and find out what the code is for the heater.
If you do not have a manual, you can find one online at the following link:
http://www.inyopools.com/owners_manual/jandy_heaters_lite2.pdf
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
119 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
US Parts Center
US Parts Center
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
