I can see the @ on the right lower corner of theQ key, but, how do I activate it???
SOURCE: I have HP Pavilion DV6
If your particular model of HP has the blue tooth installed from the
factory, turning on the wireless switch on the front left edge of the
laptop enables the blue tooth, as well as the wireless LAN. A blue tooth
icon should appear in your task bar near the clock when blue tooth is
turned on.
ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
