I am using DG31PR motherboard while connecting TV tuner card out to line in port I am not getting any audio from system line out. I am getting audio from TV tuner card out perfectly
Hi man First checkout the tuner card audio in put backside of the system one small cable comes along with tuner card it has same pins both sides one side of the pin put in audio out to the tuner card and one side audio in to the system back panel and go to audio controls in the control panel check th line in volume is high or low if line in volume is low u will not get the audio while recording
if you have any doubts give me a msg
i will solve your problem
For every tv tuner card there is line out socket, use two sided phone plug one side of it connect it to the the audio out off tv tuner and another to the Line in socket of your PC,then go the volume properties increase the line in volume. It deffinately solves your problem.If you have any problem regarding this issue leave a feedback,we will glad to assist you
YOUR MOTHERBOARD IS NOT FULLY UPDATED WITH TV AUDIBLE DRIVERS. GO TO YOUR NEAREST OUTLET ASK FOR A RECENT MOTHERBOARD CD MATCHING YOUR MOTHERBOARD SO THAT YOU COULD INSTALL THE NECESSARY MODULE.
HOWEVER, WAIT FOR MY TOMORROW'S ANSWERS IN ORDER TO GIVE YOU A BRIGDE OF MOTHERBOARD TO EASE THE AUDIO OUT.
u must connect speaker on tv tuner card;s jack. and go in control panel click on sound and audio device than select audio and change sound playback default device.thanx enjoy good luck plz vote on my comments
it been seem that you are not clear with facts to help you in proper way.
anyway i try to explain you general way.
first a internal tv card have two sound conectors, one in one out.
you must take with apropriate cable sound from output conector in your tv tuner card and the other extreme put it in line in (blue) conector in your Mb system sound card(there are last three one green one red and one blue ). now you have maket this go to program that control sound card and choose the right entry for you line in (blue conector). after that if sound isnt comming you must go to the tv settings to put the right output for your sound, and specify even is in rear or front side (in your case in rear side).prove this steps and write me back again is that helpful, or part of it so i can help you again from point you failed .
Try installing the audio card in other PCI slots.
Also check to see if the PCI gold connectors are not damaged. Do you have another PC to check this audio card out? Perhaps there may be a misalignment on the PCI connectors. Check to see if the card lines up correctly in the PCI slot.
