We have a Aurora 440QE, and there is a continuing problem with the sensing of the presser foot. We have taken the machine & computer in, and have been told that there is nothing wrong. This after hours of the same presser-foot problem at home. Only to take it home and spend more hours with the same problem. Is this a common problem?
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
SOURCE: No power on foot pedal
There is no way to change brushes on theses sealed motors and I highly doubt thats the issue. Most likely you didn't put the bobbinwinder back togeather correctly. The small spring type clip under it needs to be in the second notch of the teeth below the bobbinwinder to engage/disengage right. If you had the cover off its also possible you disconnected the wire to the circuitboard for the footcontrol, I beleive its black and red. Probably best for a tech to look at it.
SOURCE: Bernina Virtuosa 153 QE is jammed.
Where do you live in China? I'm in Hong Kong and have visited that dealer.
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
