Im on o2 line adsl+2.isp
SOURCE: Trying to turn a Linksys WRT54GS into a hub
Hope this helps!
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
SOURCE: the port of Linksys Wireless-G
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
SOURCE: the linksys wrt54gs-uk
With a DSL modem in the US, you need to confiugre the router for PPPOE with the username/password that was provided to you by your ISP. If you can't remember the name or password, contact your ISP
