The oven will sometimes start but then go to the error and beep. I have read it is a temp sensor but were is it located. My oven is a Frigidaire Model FEB 2755ABA. Thank you
Hi
F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
