Instructions Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
The volume is visible in Disk utility but not the partion. Verify says it's okay, but drop down menu says there's a problem and can't mount. Repair disk and erase disk are all grayed out.
Can you format it into FAT mode?
FAT can be seen by both Mac and PC
Plug in the USB drive. The disk should mount on its own. Open Disk Utility (Applications > Utilities > Disk Utility). The flash drive should be listed on the left side of the window. Click on it. Click the Erase tab. Make sure FAT is selected as the format and click the Erase button.
I can't format it into anything, because it is unmountable! I would be happy to erase and reformt it (into Mac Journaled) if I could mount it.
The only other way I know to solve this is to plug it into another PC or Mac and format from there. I have both so I switch between the two.
I would try and pick a PC as it tends to be less picky on the drives it reads
Same advice then, format into FAT mode only
