Panasonic Viera TH-42PZ80U Plasma TV Logo
woodie Posted on Feb 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Th42px60u Hi, I have the panasonic TH-42PX60U with the LED blinking 10 times over and over ,I have replaced the H , the PA board ,and P Board and still have light blinking 10 times .10 blinking lights on timing chart says PA SOS or Tuner SOS witch board is the tuner board ? Or what do you think ????
James DuPont Jr
Level 2:
  • Expert 91 Answers
  • Posted on Feb 12, 2018
James DuPont Jr
Expert
Level 2:
Answers
91
Questions
0
Helped
22868
Points
272
Most likely is the power board,so I hope you got a good one! The next would be a short on the SC board. The main digital board could be defective in mis diagnostic. Disconnect the SC board and see if the blink code changes. if it changes,the main board is good. If you have a good power board,I vote for a short on the SC board to be checked
5 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Jun 22, 2010
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Anonymous
  • Posted on Jan 29, 2010
SOURCE: TH-42PX60U wont turn on. Blinks 10 times.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Anonymous
  • 7 Answers
  • Posted on Nov 12, 2010
SOURCE: Panasonic Plasma TV (TH-50PZ80U) blinks 10 times,
I'm not sure of how to solve this problem but I would be interested in hearing more about your experience. I'm a factual researcher for a law firm that is putting together a class-action lawsuit against Panasonic concerning the blinking light issue many of their plasma tv models are having. If you'd be willing to share your story, please email me at [email protected].
electrotech1
Veril Gillette
  • 1126 Answers
  • Posted on Sep 27, 2011
SOURCE: TH-42PZ77U blinks 9 times and many forums indicate
Replace D board, if you still have problems , then you probably looking at a bad Y-board.
Replaced 2 TH8AH blown fuses. led flashes 10 times
Fuses do not blow (more than one) for no reason---which fuses and where?
10 blinks is usually power supply board but can be something connected to it.
3answers
My panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and reconnect . A replacement of power cable or use another power outlet is another good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
3helpful
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
I have a Panasonic plasma TH-42PX60u That suddenly stopped working. It had blown the two ifuses on the power supply board which I repaced. Now I get 10 blinks of the power light. I am prettty sure the...
Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.Have no experience in tech trouble shoothing,with multimeter,and Osclicope.Could be anythings that burn in the board well never find out.
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
Hope this helps!
TH-42PZ77U
TH-42PZ700UA
I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
23helpful
6answers
4helpful
3answers
The front led flash 10 times and the tv no turn on
Change the P.A board resolve problem. try to buy in www.shopjimmy.com.. if the front led flash 10 times is a tunner voltage problem.change this board. The P.A board Number is TNPA3620
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
