Heating & Cooling Logo
Anonymous Posted on May 27, 2012
It shuts off and blinks 11
AY-XP12ER
  • Anonymous May 29, 2012
    Hi everyone
    Sorry about the lousy problem description but what I have is a unit which blinks alternately between -0 and 11.
    Ihavn`t been able to find the error codes for this unit but have for a similar unit
    AY-XP12FR and it states Check connector CN3 of
    the outdoor unit DC fan
    motor for secure installation.
    (1) Correct the installation.
    (2) Check the outdoor unit fan
    motor for proper rotation.
    (2) Replace the outdoor
    unit fan motor.
    (3) Check fuse FU3. (3) Replace the outdoor
    unit control PWB
    assembly.
    (4) Outdoor unit control PWB (4) Replace the outdoor
    unit control PWB Just wondering which is more likely to be the problem?
Jayesh Panchal
Level 2:
Sergeant:
Champion:
  • Sharp Expert 280 Answers
  • Posted on Mar 10, 2015
Jayesh Panchal
Sharp Expert
Level 2:
Sergeant:
Champion:
Answers
280
Questions
0
Helped
124872
Points
621
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
1helpful
Pioneer Plasma Tv Throwing Code (11 green blinks on front lights) also on Screen Says (Thermal Alert Shut Down (11) )
Possible set is seeing a temperature too hot inside the set, can also be a fan in the unit if it has them it takes very little dust to slow their speed enough (dust on the fan blades).
My tv automatically shuts off then power button flashes 11 times. Can't get tv turned back on
11 blinks Fan SOS PB Board. Either the cooling fan or its control board is faulty. You have to check and locate which one has the fault. Check this link and select the site mamed 'Electro-help' for more details.
Kapag binunuksan ko po yung phone ko magoopen sya pero pagkatapos ay magbliblink sya tapos mamatay
Hi
Ilang blink yung phone mo pag nag off and on? kasi may 4 blinks and 6 blinks... paki verify
Thanks!
2answers
Flash error ilo mp3 player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
1helpful
Sony wega 36
6 times blinks shows following problem...
• +5 line is overloaded. (AY, BY, MY
Boards)
• +5 line is shorted. (AY, BY, MY Brds.)
• IC504 is faulty. (AY Board)
If you intimate exact model number of your tv, I can provide proper info.
Same tv
6 times blinks shows problem can be in following areas.
Boards)
• +5 line is shorted. (AY, BY, MY Boards.)
If you are tech-person, then understand easily.
5helpful
2answers
Shut off blinks 11 times
I have recently solved the same problem with my panasonic that was just 2years 2months old. I took off the back of the tv and brush off the dust as there was too much dust clogging the vents and fans at the back. The tv is now as good as new. Hope your luck is as good as mine. by the way i was having 11 blinks as well.
Top Sharp Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
