The genarator fires up and runs at around 1800 rpm then after a short time it increases to 2000 rpm and shuts down...
Cause of Perkins generator overspeed
The fundamental cause of diesel engine overspeed is that diesel engine loses or changes its speed regulation characteristics. Faults of fuel injection pump and governor, such as stagnation or looseness of relevant components, will cause excessive oil supply and loss of normal speed regulation characteristics, while the combustion chamber entering additional diesel or oil will change the speed regulation characteristics of diesel engine.
https://www.dieselgeneratortech.com/diesel-generators/The-cause-of-overspeed-in-a-diesel-generator.html
Solution to overspeed fault of diesel generator set
1) Forced stoppage
Once the diesel engine has overspeed, the following measures should be taken promptly to force the diesel engine to stop immediately
A. Quickly retrieve the accelerating pedal to the stop position;
B. For fuel injection pumps with exposed rods or toothed rods, the rods should be quickly pulled back to the stop position;
Replace over speed switch or throttle control.
SOURCE: genarator runs for short time then shuts down
Is the generator a disel engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
