The switch that is behind the power button on my computer has gone bad. I need to replace it however the good people at DELL have sent me 2 wrong parts when I have tried to order it from them. It is a dell dimension 3000 desktop pc. the switch has a red and blue wire going to it and there is also a 2 wire led on both sides of it. where can this part be ordered and if it cannot be ordered would a standard 2 wire toggle switch be a sufficient replacement for the switch
That is a specialized switch and it can be frustrating trying to get Dell replacement parts(I used to do Dell service in Hawaii)
this switch is unique and an on off switch is not useful at all
contact dell parts and give them the computer code(usually a series of numbers and letters) called the service tag and that should get you closer
SOURCE: Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
you have onboard video and cant install a video card. your mb. has nooooo agp or pci-ex. sounds like you installed your memory upside down and fried your motherboard. toasted it even. please dont be mad at me.
SOURCE: Side panel removal.
hey benny
this is what your cpu looks right ?
so just to answer your question. how to remove sidepanel.
you have to unscrew the screws that is located at the back and gently slide the sidepanel backwards to get it off.
Testimonial: "Thank you, It worked,"
SOURCE: added 2g to a dell dimension 3000, only 1g recognized
Memory Upgrade for Dell Dimension 3000, the Dell Dimension 3000 takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Dell Dimension 3000 to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system.
1GB Module
128x64-400MHz DDR400 PC3200, 184p DIMM, 2.5v, Sync, CL=3.0
does this match the memory you have?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
