I have set up the SONOS system for one room direct to the computer and wish to add a wireless second player, using a Belkin Surf N300. the system will not recognise the second player
SOURCE: Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
SOURCE: Belkin Wireless Modem Router, model F5D7634-4.
If the reset did not help ,i would suggest you talk to the Belkin Support team and get a replacement. Since its a new router, I assume it has an up to date firmware .
SOURCE: I have just bought this
I have the mentioned all the possible ways to get this issue resolved.
First Lets try changing the Wireless password and user name,In most of the cases this works.
1) Open a new web page delete whatever you see in the address bar(press F4 and press delete).
2) Type in 192.168.2.1 and press enter button on your keyboard.
3) Then comes the Router Configuration Page.
4) If it is asking for Password,do nothing just click submit.
5) Towards your left on the page you will see Wireless. Under that you would also see a sub Heading Channel and SSID.
6) To edit the wireless settings click on Wireless tab in the setup page.
You can edit the Wireless network name and wireless channel.
Wireless name (SSID) is the name of your wireless network. The most
recommended wireless channel is 6. You can use wireless channel 1 and
11 too.
Now change The SSID,delete the current SSID and give it a new name.
7)To enable wireless security on click on security under
wireless tab. And follow the Picture below.
For further assistance refer the link below.
http://www.corenetworkz.com/2009/07/setup-belkin-wireless-n-router-by.html
SOURCE: how to connect my belkin
No, that will not work.
The USB Port in the router is for sharing the USB Storage....
You can use only, RJ45 cables...
SOURCE: I bought a Belkin Surf N300 wireless router 4 days
Call immediately to 18002235546 we are working here to fix the issue....
