There are three main manufacturers of all the laptops in the world. Wistron is one. The usual brand names you see have their laptops made by them. They are not about to give out the circuit design/s they paid $$$$$ for, to you and me. The Integrated Circuit 3528 is used for a current to voltage converter.http://www.datasheetcatalog.org/datashee... The chipset is set up using the SOIC design, with the usual J leads. Use magnification, and follow the circuit traces from this IC, is all I can offer. Regards, joecoolvetteThere are three main manufacturers of all the laptops in the world. Wistron is one. The usual brand names you see have their laptops made by them. They are not about to give out the circuit design/s they paid $$$$$ for, to you and me. The Integrated Circuit 3528 is used for a current to voltage converter. http://www.datasheetcatalog.org/datasheets/105/500101_DS.pdf The chipset is set up using the SOIC design, with the usual J leads. Use magnification, and follow the circuit traces from this IC, is all I can offer. Regards, joecoolvette
You can't post conmments that contain an email address.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Hi Charles
The SMPS section circuit is a built in part of the main board. Just see the location. I've marked it. If you're in search for the SMPS circuit diagram, and you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Circuit diagrams of SMPS section of many popular brand devices are given.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" or the STR number of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
You're asking about the number of IC used in its smps [POWER REGULATOR] section circuit, I assume. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to SMPS [Power supply regulator] section to many popular brand TVs and other devices are given. You can fetch details there.
Check the present power supply [SMPS]; and find out the number of switching regulator IC used. Surf the site with that IC number. You will get similar circuit for SMPS there.
Hi there, As per your information i sueegst check the Motherboard Power supply connection or its called SMPS. replace the SMPS and i am sure your Laptop will start working again. If you found any sound after pressing the power button then the problem in RAM not in SMPS. Follow the few step below.
1. cjeck power connection in main board.
2. Check the green light in power adeptor its ON or
OFF.
3. check the voltage.
If all is fine then check those i mentioned in top lines. Thanks & waiting for your feedback.
