Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
Hello Daniel Ellsworth - Typically error code E23 indicates that the washer has detected that the drain pump relay on board has failed or a wiring communication. Usually this means that a certified technician will need to repair the wiring or in most cases the main control board will need replacing.
