Water started heating fine for 3 days but got to 80 degrees but now the temperature reading gauge keeps flicking to different temperatures ranging from 80 to 104 and now heater is not working.
SOURCE: I have a Waterco ElectroheatXL
Hi domedoc2...
From what it sounds like to me, you have a broken water line/pipe or fitting going to your pool heater, or maybe a fitting leaking.
Even winterising will sometimes not clear all the water from the water lines and cause them to burst over the winter.
You will need to disassemble the box that the heater is in in order to check and repair the broken water line, once that is done it should clear your digital readout warning...
One suggestion that I will make is to intstall a clear plastic (rubber) hose in the water line just before it goes into you water heater, that way if it does freeze up again this will burst instead of the plastic pipes or fittings next time it freezes and will be easy to replace.
