SOURCE: hooking up an external audio source (IPOD) to the Denon AVR 3803
sure
just get a cable with phono plugs to mini phone connector Radio shack has them
Connect teh mini phone to teh earphone jack adn teh phono plugs to the aux inputs
select aux and enjoy
SOURCE: How do I connect my Apple ipod to my Denon
GET A CONECTION THATS RCA CABLES IN ONE ENND AND HEAD PHONE JACK INTHE OTHER AND CONNECT THE RCA CABLES TO UR INUTS AND THE HEADPHONE JACK TO UR IPOD AND START PLAYING
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF]
AVR-3300/1
3.3E*
SOURCE: how to do a hard reset on a denon avr 3300
Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
Testimonial: "worked like a charm thanks for the help"
