Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
Anonymous Posted on May 25, 2012
Hilux battery replaced no start - Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Jen Wang
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 19, 2014
Jen Wang
Contributor
Level 1:
New Friend:
Welcome Back:
Problem Solver:
Answers
5
Questions
0
Helped
661
Points
9
Normally, you will have to reflash the ECU. You will need to got to Halfords or any shop that has it. Then locate the port under the steering wheel. turn the car on and it should work.
2answers
2013 Toyota Hilux 1KZTE. The engine light comes on after 1 minute from starting and then only runs at 1200 rpm with full throttle and engine cuts off after 1 minute from engine light appearing?
Please check your alternator, engine and battery with a diagnostic test from your nearest autozone. Any of these could be leading to your car-shutdown issue.
A bad alternator can even a brand new battery if it's attached to your car's system long enough.
Thank you.
1helpful
New battery - battery is drained in the morning.Replaced voltage regulator. Disconnected aircon. Still drains overnight. Ute will start and run with full battery but it drains overnight.
Easyest thing to do is pull one cable off your battery. Start pulling fuses and each time touch the cable to the battery post. When you find one that reduces the spark drastically that is the circuit to investigate.
2answers
While driving on dirt raods the radio in my Hilux, 2013 model, changes channel on its own. Dealer told me the battery may be low. They are no help.
Hi,this type of radios with their batterys cause lot of headake:-)Where the fake AC is the knobs that say driver and passenger are actually screws,so you have to unscrew them and you will be able to locate and replace the battery as well.Hope this helps
Toyota immobiliser
When a battery is replace there is a possibility that certain elements of the CPU program become corrupted. Try using a scanner to reset the CPU program in the ECM to see if that turns on the immobiliser section.
Toyota hilux misfiring after replacement batteries
Please read the causes of engine misfires here. A tip look for any vacuum hoses that may be disturbed and leaking.
1helpful
Im getting no power what so ever to start my 1988 toyota hilux?
Check all earth points, you can check this website out, these will help you with any parts you want. http://www.milneroffroad.com/HILUX.HTM
2answers
Starter barely turns over. battery is good.
the leads to the starter may need replacing, the connections on the battery and starter could be loose
the contacts in the starter relay may be worn out ( had that problem on my hilux ute)
3answers
No start
Replace battery cables.
Hilux ln130 wont start with key but will crash start
if it is automatic transmission try to start it in neutral, and see what happend, but if it come whit manual transmision, then check the cluth switch, you can by pass the switch and try to start it, if it works then replace the sw, but if not the look to see if there is a starter relay and replace it, most of this come wiht starter relay and they fail.
Top Toyota Vehicle Parts & Accessories Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
