Question about Vizio GV42L 42 in. LCD Television
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
My Vizio 42 inch LCD TV is having intermittent problems. The standard channels go fuzzy (the picture is stretched horizontally and there are fuzzy horizontal lines throughout the picture). I already checked and it is not on zoom. Meanwhile, HD works fine. This problem doesn't happen all the time. Some days it's fine, other days it's not. Cablevision already came out and said the signal is fine (and the non-Vizio TV downstairs is not having this problem so the cable signal is not the issue). Also, when I record a show on DVR when it's fuzzy and watch it when the standard channels are not having the problem, the recording is fine (therefore it's not the cablebox/DVR problem). Help!!!
You might have an overheating problem- make sure you have adequate ventilation around your tv
Posted on Jan 29, 2009
6ya staff
SOURCE:
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
ImagypsyRe:Vizio 42" LCD TV Screen randomly
You should definitely return it. It is most likely due to backlight malfunction and or backlight invereter malfunction. Either ways you should return it and demand for a replacement if its under warranty.
May 30, 2011 | Vizio 42 in. LCD TV
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Mar 13, 2009 | Vizio GV42L 42 in. LCD Television
My Vizio 42in. is really fuzzy
If the picture is clear when using a DVD and remains "fuzzy" only with cable, then either the cable is bad or the up-conmvert from standard def to Hidef is creating the "fuzz". Depending upon the method used by the set to perform the "up-convert", the noise you are seeing may be normal.
Dan
Jan 27, 2009 | Vizio L37 Television
Brand new 42 inch flat screen is always FUZZY
contact the manufacturer man!!!! whoooooooooooooooooooooo
Dec 02, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
1,371 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
