Onkyo TX-SR606 Receiver Logo
A
Anonymous Posted on May 24, 2012
RCR4258R/RCR4358R Brand code for ONKYO
Need code to program remote
5 Related Answers
A
Anonymous
  • Posted on Sep 28, 2008
SOURCE: NEED CODE TO OPERATE TOSHIBA T.V. ?
go **** yourself! Talk about spending money to fix a problem fuckin hypocryte
Anonymous
  • Posted on Dec 30, 2008
SOURCE: trying to program my onkyo
32905, 30490,...
have a nice try
Anonymous
  • Posted on Mar 28, 2009
SOURCE: i need the remote code for my onkyo tx-ds575, my
Get yourself a remote from Logitech Harmony family. It magically knows all the possible codes. And the support is VERY helpfull.
Anonymous
  • Posted on Jun 04, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Anonymous
  • 2335 Answers
  • Posted on Apr 20, 2010
SOURCE: i need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
2answers
I have a onkyo resiver and a olevia unaversal remote are thay compadable and whats the cods
If the Olivia remote control have set-up code/s for Onkyo brand devices, you can. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
tip
Onkyo Remote Control Programming Would you like help programming your Onkyo...
Would you like help programming your Onkyo remote control to control other devices?
To program your Onkyo remote control, follow these steps:
  1. Hold down the REMOTE MODE button for which you would like to enter a code, and keep pressing it down.
  2. Press and hold down the DISPLAY button until the remote indicator lights up (about 3 seconds).
  3. Within 30 seconds, use the number buttons to enter the 5-digit remote control code for your device. (look these Onkyo remote control codes up in the codes list.)
  4. The remote indicator will flash twice to indicate a successful programming.
The Onkyo remote control codes, listed by brand, are available here.
I hope that helps.
How do I use an RCA Universal Remote RCR4258R for a symphonic brand television
Well you need to program it with the codes for that brand of TV. The other method is to use the "Code Search" option on the RCA remote.
I need the code for my onkyo code rc-693m
http://electro-medical.blogspot.com/
Need a working remote code to a ld3249 apex digital tv for a rca rcr4258r
0025,0022,0027. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Remote Control Code Question
Codes to check with Onkyo brand are; 0284,0288,0281,0228. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Att uverse remote will not program my onkyo txsr806 avr. Please help
The remote control might not have direct setup codes to Onkyo. Try a code search procedure. If there is any hidden code, you can win. Otherwise, buy any other brand universal remote control, which have setup codes to Onkyo, in its code list. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Norcent LT2023 for (bought a new remote) RCR4258R/RCR4358R
Click here to download the manual to your remote control along with its code list.
I am not able to program this RCA4258R/RCR4358R universal cable, can you guide me with this
You can download a manual and codes list from
http://rcaaudiovideo.com/remotes/4-5-devices/?sku=RCR4258R
Let me know if you have any more questions. Please make sure to rate this solution. Thanks.
RCA RCR4358 remote
http://audiovox2.info/docs/common/RCR4358R/RCR4358R_OM.pdf
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
