Sanyo 24KS32A Cool Mini Split Air Conditioner Logo
Anonymous Posted on Nov 25, 2008
TV Remote Control Symbols.
Can I download a list of all the standard symbols on a television remote control and what they do? (e.g. Model: ICR81602).
Tony Henson.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2643
Points
Sorry, I have NOT asked for assistance on a Sanyo air conditioner. But I have asked about standard symbols on remote controls and not received any replies yet.
Tony.
Celestial television
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. This detail will be with the code list document attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy.
I can't find a remote for my Prima TV model#XT-2799. Help!!
Universal remote codes for Prima TV are:
1019 0165 0116 0167
Just note these codes, and buy a universal remote control, which have these setup codes in its code list.
If your TV asks for a five digit code, buy one RCA RCR 311STN model remote control. Five digit codes for this remote control, with Prima tV are:
10761, 10783, 10815, 10817
I need download the user guide of Mitsubishi rkn502a remote control
Search Results
    [PDF]user's manual mitsubishi daiya room air ... - 3D Air Sales Ltd
    www.3dair.co.uk/DOWNLOADS...manuals/O&M%20RAC%20-%20SR...
    MITSUBISHI DAIYA ... performance, read and follow this User's Manual carefully before using your air condi- ... Operation and indication section for remote control . ....Symbols which appear frequently in the text have the following meaning:.
    Air Conditioning User Manuals - Mitsubishi Electric Australia
    www.mitsubishielectric.com.au/Air_Conditioning_Use...
    Mitsubishi ElectricUser Manuals/instruction booklets (including remote control instructions) forMitsubishi Electric Air Conditioners. ... Air Conditioning Downloads · Residential Air ...Need to know how to operate a Mitsubishi Electric air conditioning system?
    Remote Control Symbols - Mitsubishi Electric
2helpful
Can not get the directv universal remote to work with my older
I can help you with your Sony TV & DirecTV remote control.
This is a list of all the Sony TV control codes for DIrecTV remote controls:
10000, 10810, 10010, 10011,
10080, 10111, 10834, 11317,
11685, 11904, 11925, & 10505.
There are so many codes to try for Sony TVs and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
1helpful
Can not unlock tv
try to press the display button on your remote for 5 sec, when the lock symbols disappear turn off your unit on the remote and unplug it
15helpful
Air conditioner remote
This is the standard meaning of symbols in the remote control.
Manufacturing coeds for Insignia
Go here: http://service.us.panasonic.com/operman/Default.aspx select remote control guide, find the model of your remote and get all the available codes for that remote on all the devices it supports. Site also lists owner's manuals in pdf for download..
Bill
Tv keeps turning off
take your remote control and find the symbols shows watch click,then will show you the time setting if you want my be your tv to turn off 10 mn or 5mn or 60mn.then turn off the time there.
Top Sanyo Heating & Cooling Experts
Jay Finke
Jay Finke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
