Its a zte score...forgot my pin now im locked out of my own phone...please help
Should be the last 4 digits of your phone number.
If forget the password to unlock X500, you can refer to the following method, which can reset the phone and erase all the user personal information.
1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display "ZTE", press the Menu key at the bottom of the screen;
3) Choose "Wipe data/factory reset" through volume key
4) Press "Camera" key to confirm the above item
5) Choose "YES...delete all user data"
6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
SOURCE: UNLOCK A TELSTRA LOCKED ZTE F156
unfortunately you cant...you have to take it in and have it reset..if your service provide it..if you have a home phone call your service pro and they can asst you..if you have patients..lol
SOURCE: i forgot my code that unlocks my metro pcs zte phone
You can try all zero's (Example: 000000, 0000). Now since your device already has a custom unlock code, more than likely you will need a customer service representative of MetroPcs to assist you, where such information can be accessed.
SOURCE: open my phone
did he forget or you just asume that what is the number he gave you last is the one you just have to wait 10 min after 3 wrong password
SOURCE: LOCKED OUT OF LG XENON PLEASE HELP :(
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
done it already
SOURCE: forgot my phone lock pin
Lost Pin cannot be recovered. You need to enter a wrong pin 3 times until you get the PUK code.
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the PUK code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
Can I get around this?
