Bose Acoustimass 6 III System Logo
Anonymous Posted on Apr 17, 2017
Do I have to have a powered bass module to make the cubes work?
I bought a bose acoustimass 6 series III speaker system with a yamaha receiver. It worked great. Then our house was broken into and the powered bass module and receiver were stolen. I am trying to piece the system back together with a sony receiver and a non powered bass module from an acoustimass 5 series II system that I got second hand. I can't get any sound out of any of the speakers. Do I have to have a powered bass module with these cube speakers? If not, what kind of cables do I need to patch the system together?
Thanks in advance, any help would be greatly appreciated.
5 Related Answers
Anonymous
  • 85 Answers
  • Posted on Mar 01, 2008
SOURCE: Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Anonymous
  • 1257 Answers
  • Posted on Jun 17, 2008
SOURCE: bose acoustimas double cube speaker
Try to see the 2 ends at the speaker you have open and arrange that 2 springs and 2 metal clip to that 2 ends to reconfigure it properly...
Anonymous
  • 5 Answers
  • Posted on Apr 10, 2010
SOURCE: Bose Acoustimass power
I have the same problem TOO!#$#@% Anyone out there?
Anonymous
  • Posted on Jan 31, 2011
SOURCE: Can I use Bose double cube redline speakers with
yes i was back in nam whence i came across this devil of a problem. me and jimmy had some bose triple gauge subwoofers fully loaded in our packs. we needed serious wooferage and luckily we got captured and rendered prisoners. the namese transferred us to africa for some unknown friggin reason. Anyway we ended up on an electronic dump in nigeria and that is where all of our problems came to an end. those **** hooked us brothers up and got those triple gauge subwoofers rockin straight out of our backpacks. we were **** scared at first (maybe thats why we couldn't feel it when they plugged those sound pumpin, rocket eating, puppy skinning machines into our livers). We were set, me and jimmy just cruising, walked all the way home with bose triple gauge mother humping subwoofers pumping straight off our livers. Just plug em in bro. Those f&*kers will rock your world. Copyright. Me and Jimmy in Nam 1932. Jesus christ I'm drunk, maybe I should write books instead of working as a bricklayer. "JIMMY TURN THAT F^*KIN TRIPLE GAUGE DIRTY *** FAT GRANDMA SUBBY FROM THE GREAT GUYS AT BOSE DOWN..............thanks"
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Mar 24, 2011
SOURCE: I have bose acoustimass 15.
your acoustimas requires you to connect all speakers outputs to it first then to the speakers.
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
Can i connect my bose acoustimass 800 with any other receiver?
hi,
Surly you can connect these speakers to any receiver. It has an active subwoofer and 5 passive cube speakers. It can handle power up to 150W.
ok
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
1helpful
2answers
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
I have hooked this up to a working reciever that
Fill in the blanks about the working receiver.
You mention another subwoofer, which suggests your receiver manages the bass and possibly sends most or all of it to the sub.
If it's NOT sending the bass to the speaker terminals you use to drive the AM5 that would explain it's virtually silent bass module.
If those speaker terminals on your receiver can be set to LARGE, do it. Otherwise they assume the speakers are incapable of handling bass.
1helpful
2answers
Which subwoofer????
Cameron,
I have the same problem, check these link and you will understanding more how it works. My understanding was bose cube cannot work with other receiver directly, it has to be work with bose's woofer (they call module) and they have specific wire to connect. So I give up to switch to bose even they match my deco and go back to traditional. Good luck.
http://www.allbose.com/Question.aspx?id=64108
http://products.bose.com/pdf/customer_service/owners/am6_guide.pdf
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
