SOURCE: PS3 Won't run.
actually it sounds more like the FAN seized/died. if it overheated the thing wouldnt even try to turn on. the back of the ps3 is acually pretty vunerable to getting smashed in a little. ( took mine thru an airport. the (monstrous) fan inside the badboy pushed into the heatsink and couldnt turn. this triggered the ps3's save-thine-self mod ie turn off before bad stuff happened. listen/feel for the fan when you turn it on. if there is no flow take it apart and see if the fan moveds freely in place otherwise genty bend on of the three metal support brackets to get it free of the heatsink and try that.
SOURCE: playstation3 cant turn on><
try turning the main swith on and off a few times, then power the front.
let me know
thx
SOURCE: PS3 TURNS ON,GREEN LIGHT FOLLOWED BY YELLOW LIGHT
Your hardrive has probably crashed. I have been trying to fix mine and after weeks of studying, i found out I need a new video card. If you have demos then my problem may be yours too. If you are trying to play games and it crashes, then it's the video card. The only game that works with a broken video card is Street Fighter 4, but you can't save. Visit this link for better instruction on how to fix non-video card problems. I hope it helps!
SOURCE: while charging, i noticed that a red light was
Try removing the battery, and give it 30 seconds or so before reputting it in. Then try to start it again. If this doesn't work you may have to take it into a shop for further assistance.
SOURCE: my 12th old ps3 has been faultless until 6/2/10
If ur ps3console wont start up....then the things to check are>>> 1.check urpower cable 2.check whether u have inserted the disc properly and precisely.3.check the insertion of memory card... 4.check the video port.......
still the same problem,don worry check out thefollowing Repair Guide..... CLICKHERE
