SOURCE: My Mitel 5340 will not
You need to set this extension up in the Call Rerouting form in the PBX. Program the First alternative to go to the voicemail extension.
SOURCE: What does option 128 missing
It means that your DHCP server on your network is missing the options to allow your phone to boot up. After a month (time on this message), I hope you've managed to get the issue resolved. If not, I hope you've fired your IT support team - they should be able to get this resolved quickly.
Sincerely,
Mark
SOURCE: no dial tone on Mitel
The network isn't configured properly for your phone to boot up. You should contact your phone vendor or system administrator for support.
SOURCE: Handset on Mitel 5340 IP
Are you referring to the Mitel Cordless handset or headset? The handset and headset must be paired to the module on the back of the phone. Press and hold the button until the display indicates pairing. Then press the Answer button on the handset or headset.
SOURCE: my Mitel 5340 ip phone will not turn on. i've
Is it plugged into the correct port (not the PC port)? The phone requires Power Over Ethernet - this is either done with a PoE Switch or PoE injector. This should provide power to the phone so it can boot.
