It can be most aggravating when an important photograph is accidentally deleted. If you have an iPhone 6, then thankfully, there are a few options available for flv files recovery from this device. Remember, it is good practice to back-up your photographs every now and again by saving them onto an external storage device.
One of the first things to do in trying to
retrieve deleted photos from an iPhone 6, is to open the Photos app on your smartphone. Once you have done that, do the following steps:
1.Select the "Albums" menu.
2.Select the album that you need and then select "Recently Deleted."
3.A list of all the recently deleted photos will appear.
4.Select the ones that you want and then tap on the "Recover" button to recover all the photographs that you selected.
5.All restored photographs will be sent to the album in which they were originally located.
If the photographs that were deleted were backed up in iTunes or iCloud, they can also be recovered. The important thing to remember is to have either iCloud or iTunes backup turned on at all times. If you are unsure how to do so, here's how:
1.Go to the "Settings" menu then select "iCloud."
2.Under "iCloud", select "Storage and Backup."
3.Then turn on the "iCloud Backup" feature on your iPhone 6.
4.As long as your iCloud backup is up-to-date, then all your photos can be easily restored to your iPhone 6 in case of accidental deletion.
Backing up your photographs to iTunes is equally as easy as backing them up to iCloud. However, once you connect your iPhone 6 to your computer or iPad, you need to ensure that iCloud is turned off; you can back-up to one or the other but not both apps at the same time.
If your photos have been deleted, then recovering your duplicate photos from iTunes backup or iCloud backup is not a problem. Simply launch iCloud or iTunes, right click on iPhone (the device in question), select "Summary", and then select either "Restore from iCloud Backup or
"Restore from iTunes Backup." Once that is done, wait for "Restore in Progress" to complete and your device restarted.
When all else fails, a reliable data recovery software can be used to recover deleted photos from an iPhone 6.
uFlysoft is one such user-friendly software that gets the job done quickly and thoroughly. The process is simple and takes these easy steps:
1.First, connect your iPhone 6 to your Mac computer then launch the uFlysoft data recovery software. You never want to launch a data recovery software directly from the smartphone from which you are trying to recover lost or deleted data.
2.Select the "Recover from
iOS Device" option.
3.The software will then scan your device and present all the recovered photographs for you to preview.
4.The recovered photos can then be saved to any storage device or the computer itself.
RE:
http://www.uflysoft.com/
Hello , I usedhttp://www.cardrecovery.com/download.asp and it worked. Tahnks
You're welcome. If you don't mind, please show your appreciation by clicking on the thumb-up icon to show that my solution was helpful.
