Ranger RCI-2995DX Base Scanner Logo
Archie Andrews Posted on May 23, 2012
Need to know how to wire a sadelta echo master plus classic mike to a ranger rci 2995 cb radio
Need to know the wiring from mike to radio thank you
3 Related Answers
Anonymous
  • Posted on Oct 22, 2009
SOURCE: is the rci 2995 dx a good base radio for the
how can I get more modulation out od this radio?
Trevor Berg
  • 3 Answers
  • Posted on Sep 30, 2011
SOURCE: I HAVE A SADELTA BASE MIC NEW MODEL ON MY RANGER
those mics are supposed to work for most radios ,,,if your getting good audio reports,,i wouldnt worry about it ,,im thinking of getting one for my icom 735 radio,,how much did u pay and where did u get it,,,,if you are worried about damaging your radio,,get a hold of ranger ,,and ask them about the mic
trevor berg
Ironfist109
Iron
  • 3018 Answers
  • Posted on Oct 17, 2011
SOURCE: Manual 2995 RCI Needed.I would like to order one
  • Hope this helps.
Regards, Tony
How to wire a Sadelta M3 to a Cobra 29 LTD Classic
I believe to wire a Sadelta M3 microphone to a Cobra 29 LTD Classic CB radio:
The Sadelta M3 microphone has four wires: white, shield (bare wire), red, and black. The Cobra 29 LTD Classic CB radio's microphone jack also has four pins: Pin 1 (Audio), Pin 2 (Ground), Pin 3 (Transmit), and Pin 4 (Receive).
To wire the Sadelta M3 to the Cobra 29 LTD Classic, you need to connect each wire from the microphone to its corresponding pin on the microphone jack. The white wire carries the audio signal from the microphone's element to the radio, the shield wire provides a ground connection, the red wire activates the radio's transmit function when the microphone is keyed, and the black wire is used for receive audio.
Here are the specific steps to follow:
  1. Cut off the existing microphone plug on the Sadelta M3 microphone cord.
  2. Strip about 1/4 inch of insulation from each of the four wires in the Sadelta M3 microphone cord.
  3. Connect the wires to the pins on the microphone jack as follows:
  • White wire to Pin 1 (Audio)
  • Shield (bare wire) to Pin 2 (Ground)
  • Red wire to Pin 3 (Transmit)
  • Black wire to Pin 4 (Receive)
  1. Solder each wire to its corresponding pin on the microphone jack. You may want to use a multimeter to verify that each connection is solid and that there are no shorts or open circuits.
  2. Once you have soldered all the wires, test the microphone by speaking into it and checking that the radio's TX meter moves as you speak. Also, check that you can hear audio through the radio's speaker when receiving signals.
  3. If the microphone is working correctly, use heat shrink tubing or electrical tape to cover the soldered connections and provide strain relief for the wires.
Note that some microphones, including the Sadelta M3, may have additional features such as a built-in amplifier or power supply that require additional wiring.
1helpful
RCI 2995 DXCF. Where can I get a wiring diagram for installing a Turner Plus 2 microphone?
Hi, I use this website elektrotanya.com to get free schematics,
They also have the Ranger RCI 2995 schematics available.
Hope this helps
Rci 2990
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
How do i get parts for the sadelta echo master plus microphone
depends on what parts you need but this company sells a few parts for sadeltas but limited !!! www.hyelectronics.com good luck !!!!
Where does the e-chip plug in on the ranger rci 2995
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
2helpful
I need to wire a sadelta es 880 echo chamber to my cobra 25 LTD ST MOBILE . if i have locator grove on plug upwards . ty for any help you can give
First of all, if you will look closely at the end of the mike plug, you will see numbers 1-4. 1- is shield, 2- is audio,white, 3- is transmit-red, 4-is receive,-black,.....hope this was helpful...
Omegaforce s45 mic wiring
Sadelta
1-Shield - Ground
2-White - Audio
3-Brown - Transmit
4-Green - Receive
Does this color code look like what you have in your mic?? sorry for the delay,,, Mechanic
Top Ranger Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
