Kenmore 24032\24036 Top Load Washer Logo
Posted on Nov 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 Series will not fill up with water
My Kenmore 80 series washer will not fill up with water at all!! It will agitate but that is it. Model number is 110.20852991 What do you think it could be?
  • SATworks Nov 28, 2008
    larryyb says that the pressure switch is probably bad, but what is a pressure switch? I can't check it if I don't know what and where it is.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 291 Answers
  • Posted on Nov 24, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
291
Questions
Helped
88507
Points
678
If your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
1helpful
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
1helpful
2answers
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
6helpful
3answers
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
1helpful
2answers
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
16helpful
4answers
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Hot water wont shut off
solenoid valve is jammed open
replace
Alexander
vince
