My cousin set up BIOS password then he forgot it. Whenever it starts, we could not log in because we forgot the password. Is there any solution for this issue?
The BIOS password is probably the Power On Password.
This method may not work. Remove the BIOS battery for 20 mins until the charge in the BIOS is depleted. Insert the BIOS battery go into the BIOS setting and set the Date and Time etc.
If this does nor work then the BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work and there is probable no backdoor passwords.
The Sony support maybe able to offer a solution, check the support WEB site..
SOURCE: Sony vaio VGN-S56GP pawer on Bios password
Hello, I can unlock ANY SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto [email protected] WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
SOURCE: recovering password or reseting
Well the failsafe way to do that is to remove the CMOS battery from the motherboard. But that involves opening the case to the laptop and finding/removing it.
Opening a laptop is certainly not an easy thing to do, however.
Another option is to find your model number, go to the SONY website and find the manual. There may be instructions in the manual on how to clear the CMOS password.
Also, there is sometimes a RESET button on the bottom of laptops. (It'll usually require a paperclip to activate it.) If your laptop has that, then it'll most likely clear the CMOS password.
Good luck.
SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password
Posted on 30 December 2008
Tags: Tech News, Tutorials
If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
this post anwsers all hyjackers that pop in or out +
and over-rides lies and spammers and $calpers.
https://www.sony.com/electronics/support...
8 manuals to read, are you rested up.? read the FAT one (big'n)
RTM read the manual yet to learn what PW was set and WHERE?
where matters
power on (machine PW)
bios admin (yes)
bios users. (none)
hdd encryption locks, bios
hdd encryption locks , BITLOCKER.
windows login , last.
page 95 says(states) amazing no, omg it's in the manual....
"you can use BIOS functions to set two types of passwords: - Machine password: Allows users with administrative rights to change all the setup options in the BIOS setup screen, as well as to start the computer.- User password: Allows the standard users to change some of the BIOS setup options, as well as to start the computer. To set the user password, you must first set the machine password.?Entry of the power-on password will be prompted after the VAIO logo appears to start your computer.!If you forget the machine password, the password needs to be reset and a fee will be charged. To reset the password, contact an authorized Sony service/support center. To find the nearest center or agent, see Finding More about Your VAIO Computer (page 5).You can reset the user password at the BIOS setup screen by entering the machine password."
https://www.youtube.com/watch?v=5bV61PjS...
see KEY:"????
this means it has a back door PW, if you see that red box and the KEY:NNNN that is back door PW tech.)
best is to only read only posts on series PC called. VPC
this is not spam this is me search for you , in google and YT the correct way "VPC" Password.
hit enter 3 times, see key: NNNNNNNNNNNNNNNNNNNNNNNNN
that NNNNNNNNNNNNNNNNNNNN is the PW key HINT for ONLY YOUR PC
some sites charge money to reset it, charge that to the cousin. for sure.
https://youtu.be/5bV61PjSFP8?t=14
last page
in trouble shooting document, read.
I cannot remember the power-on passwordIf you have forgotten the power-on password, contact an authorized Sony service/support center.
A reset fee will be charged
next time write it down and keep kids off dads NON TOY GRADE PC.
