E-Machines M5310 PC Notebook Logo
A
Anonymous Posted on May 22, 2012
How to reset bios EMachines E528 - E-Machines M5310 PC Notebook
1 Related Answer
Anonymous
  • 600 Answers
  • Posted on Jan 01, 2011
SOURCE: I CAN'T FIND MY BLUTOOTH
If your sure you have it -you will find the settings in-Control Panel-- go to START>CONTROL PANEL
Intel rst service is not running
eMachines eME528-2325 Specifications
you left off 1/2 the real model #
Mobile Intel® GL40 Express Chipset , A LAPTOP PC
NO OS told, w7 new it had (still)?,
well that needs a driver to work AND DOES NOT WORK ON NEWER OS NOT TOLD..
THE MAKER OF THIS LAPTOP HAS GL40 DRIVER THAT USES NONE RAID MODE, (laptops can not use raid, no space for 2+ hdd) that means only gl40 drivers work;.
here they all are
https://www.emachines.com/ec/en/US/content/drivers.html
11 drivers there for one PC (this one) per OS.
w7
the 2 marked Intel must be loaded
best is first turn off RST mode in BIOS (no raid)
and set ACHI only . there.
RST is RAID and not used.
pitfalls (no OS told at all guess nasty XP/VISTA.)
the coin cell is dead, and if is, cannot be ignored
the bios reset on bios page 1.
RTS (intel raid chip) disabled in Bios
all sata ports turned on.in bios.
set SATA to ACHI mode, for modern windows. in bios.
a good HDD that passes smart tests.
boot order set to hdd0- first. in bios.
keyfacts, Intel ended all support for the old RST chip and must be disabled now for all newer OS.
some RST drivers see bios RAID off and load in ACHI mode automatically or not.
save
exit bios, cold boot it to USB windows install media
and load the secret OS now.
fresh, (I erase all HDD that had virus first )_
Emachines e528 with out charger I cannot use my laptop but my battery is OK.
I assume that you are looking for an e528 adapter. There are many adapters available on Amazon and eBay (search for "e528 charger"). If instead you are saying that the machine works fine when the charger is plugged in, but not when you are running off of the battery, then how do you know that your battery is OK?
E528 bios order
you would like to order a bios, emachines might sell them.
My laptop camera not working
You must have a Video Program and proper Drivers.
Go the manufactures web site for this material.
Operating system not found
If you are still having problems ?
F2 or F12 to enter you Bios setting.
Set to default setting ( Last Page ) and Save.
Hope this helps
Emachines e528 load to blank black screen after windows loading
Sounds like you lost your Operating system, Probably going to require a reformat to repair
4helpful
RESTORE EMACHINE E528 TO FACTORY SETTINGS
Try restarting...when the eMachines splash screen appears (e)...press Alt+F10 at the same time...this is the method I learned about when my eMachines recovery management would not complete the restoration process...mine is a desktop pc...but give it a try and see what happens.
1helpful
2answers
Does e528 have webcam
That depends on the model, because there are two different e528. One is called e528-2012, and that model does have a webcam. The other model, e528-2325, does not come with a webcam.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
