Pentax Optio S10 Digital Camera Logo
Posted on May 22, 2012
How do i cancel green mode - Pentax Optio S10 Digital Camera
chris singleton
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on May 22, 2012
chris singleton
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
17
Helped
8148
Points
29
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode
Service mode
Which printer model you are using??
Example: For cannon printer follow the given steps....
  • Plug in power cable
  • With the printer power turned off,while pressing RESUME/CANCEL button,press and hold the POWER ON button. (Do not release the buttons)
  • When the Power LED lights in green,while holding the POWER ON button,release RESUME/CANCEL button. (Do not release the POWER ON button)
  • Press RESUME/CANCEL buttons 5 times. (Each time the RESUME/CANCEL button is pressed,the ALARM and POWER LED lights alternately. Alarm in orange and power in green).
  • When the POWER LED lights in green the printer is in service mode and ready for service operations.
***If you need any technical help on printer then you can reach at here
tip
Waste ink full on Canon ip2000 series, and service mode
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan (LTR)
2helpful
Error Code no. E000067-0110
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
If the issue still persist contact manufacturer
1helpful
2answers
Canon pixma ip4200 green & yellow light blinks 12 times and cannot print. what am I to do? pc connected, cable connect.
You might need to reset your printer so it can work again. please follow the steps below. It is important to familiarize yourself to the steps before doing it.
Here it is.
Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Hope this helps.
1helpful
Blinking ornge light
reset your printer if you try you can i will give you 6 tips
Here this manual way step by step to resetting waste ink counter on printer canon iP4000.
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable.
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
see you can where is blinking orange light
.error 1700 says waste ink absorber nearly
(In waste ink absorber replacement, perform
the EEPROM information print to identify if the main and/or platen
waste ink absorber should be replaced. After replacement, reset
the applicable waste ink counter(s).)
Waste ink counter reset See “Service mode operation
procedures” below.
The following 3 methods are available:
- Resetting the main waste ink counter (0%)
- Re-setting the main waste ink counter
value to 50%
- Resetting the platen waste ink counter
(0%)
Power button.)
position.
<Waste ink counter reset procedures>
1 time Orang
e
1 time Orang
e
Japan
3 times Orang
e
Other than Japan ltr
2helpful
How can I reset the waste ink counter in the printer Canon Pixma IP4200 ?
you can reset it following this procedure:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold POWER button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
Then you should do this http://erkinson.altervista.org/blog/2010/canon-ip4000-disassembling/
4helpful
How to cancel ''green mode''? camera has 8.0 megapixels Pentax Lens, 3 x Optical Zoom 6.3mm - 18.9mm
The Green mode locks out the user from the camera menu. To cancel the Green mode you must press the Green button again.hope this helps
Is there a way to replace or empty the waste ink absorber
There are two overflows so chances are it is the first one that is almost full please try this
  • With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  • While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  • While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  • When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  • Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  • Press the power button to exit service mode.
Note : If you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
My iP8500
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights
in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
4) When The LED lights in green, press the Resume/Cancel button the specified number of time(s) according To the function listed in the table below. (Each time
the Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation
completes, the printer returns To the menu selection mode automatically.)
in the destination settings mode, press the Resume/Cancel button the specified number of time(s) according to the destination listed in the table below, and press
the Power button.
Note: After setting the destination, confirm the model name in service test print or EEPROM information print.
[See 3.4. Verification Items, (1) Service test print, or (2) EEPROM information print.]
To the top
Time(s)
LED
Function
Remarks
0 times
Green
Power off
When the print head is not installed, the carriage returns and
locks in the home position.
1 time
Orange
Service test print
See 3-4. Verification Items, (1) Service test print.
2 times
Green
See 3-4. Verification Items, (2) EEPROM information print.
3 times
Orange
4 times
Green
5 times
Orange
Proceed To the step 5), and follow the destination settings
procedures.
Destination
1 time
Orange
Japan: iP8600
2 times
Green
Other than Japan, non-support of CD-R printing (A4): iP8500
3 times
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
