SOURCE: need vista driver for cannon Powershot s40
http://software.canon-europe.com/products/0000587.asp
here u can select vista and then the programs and drivers
if it helped rate fixya
SOURCE: Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: Cannon PowerShot A630 LCD screen
remove two small screws on the end of the display and slid off cover.check to see if the blue and yellow wire conectors are properly seated in place. mine were not. i think twisting the display pulls them out
SOURCE: my cannon powershot sd1000 lcd
you can get a replacement lcd unit from canon at 800-652-2666, part number CM1-4131-000 cost $18.40 shipping ups ground $6.00 total cost $25.87. Good Luck!
SOURCE: Memory card error on Cannon Powershot sx 10
The camera probably wants you to format the card in the camera. Download any pictures first using a cardreader if necessary.
