I have tried tapping f2, f12, f8 while turning laptop on, but not triggering anything. Still goes to black screen with "error loading operating system" message after quickly showing the dell logo screen. Can't get past that to try any solutions mentioned in various forms. How do I get past that screen?
SOURCE: Dell Inspiron 1501 black screen
i think your system's files is corrupted due to improper shut down or sudden lost of system power.so better do fresh installation of operating system or do recovery by booting up windows xp from cd rom.
SOURCE: Screen goes black after windows XP logo, then no response.
I would suggest checking your hard drive to see whether or not it has a bad sector on it.
SOURCE: Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
SOURCE: My Dell Inspiron 1520 will not load
Hello, Beth.
The most common reason is memory. Try reseating (remove and reinsert) the memory, first.
Power off the computer and disconnect all cables. Flip the laptop to the back. Remove the battery. The memory cover has 8 screws. Remove the memory modules at a
25 degree angle and reinsert them by pushing them down firmly by the ends.
If reseating the memory doesn't solve your problem, one module may be bad. So, remove and test each module one at a time.
Hope this helps.
SOURCE: Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
