How do i reset my tv to its original settings
SOURCE: Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
SOURCE: young son locked tv parental control
Under the main menu, go to the Parent tab and enter the Master Password: 4357. This will completely clear the present password. You can enter a new one afterward.
SOURCE: Sony FD Trinitron WEGA KV 32FS120
My Sony KV-32FS120 won't power up, LED blinks four times, replaced the Vertical Deflection Booster (IC561), still dead.
SOURCE: Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
I have a Sony FD Trinitron model KV-32HS510. Recently I seem to be losing 1 color in the picture after it runs for awhile.It's re-acuring.Sometimes it goes green. Can you help?
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
