Recovery disc
Most times the recovery discs don't work. Why not just get an operating system disk and reinstall the operating system?
Have you tried doing a System Restore? System Restore will let you
select a Restore Point (date and time) before you started having
problems. System Restore will not delete your data, documents, music,
pictures, videos or programs (unless the program was installed after the
Restore Point you selected). System Recovery on the other hand will
delete everything and set your system back to the point when you first
purchased it.
To start System Restore click Start/Programs or Start/All Programs.
Click Accessories/System Tools/System Restore. When it opens you will
have the option to select another restore point (date and time) than the
one shown.
SOURCE: restoring averatec 3150 laptop to factory setings
With no disk you cannot restore your computer to a factory settings, at least that your computer has a second disk with the restore settings installed on it (usually this disk is called restored)
SOURCE: How do i restore my toshiba a105 laptop to factory setting.
if you would like to reset to factory default turn off unplug power remove battery wait 30 seconds replace batt & power hold down zero button restart pc do not release zero button until you see screen flashes and you see cursor blinking at top left release follow instructions for restore to out of box state pc will restart several times do not touch until you see choose language page this is for windows 7
SOURCE: i have no system recovery disc but i want to factory setting
Providing the laptop was built after 2005 then there should be a recovery partition on the laptop.
Turn the laptop on and repeatedly press the F10 key, this should get you into the recovery partition and allow you to factory restore the laptop.
Regards.
SOURCE: restore factory settings for my samsung r519 laptop win7
system restore can do this for you if windows does work
if not recovery disc are sold on line through ebay and other web sites
