New batteries. in correctly. All buttons work and light up indicator except code search. Ever hear of that or have an alternate solution to programming? Button seems fine, normal. Not loose or damaged.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
SOURCE: RCA Universal Remote stopped working
I also have the same problem with my rcv remote and it started when the batteries accidently feel out
SOURCE: code button
I have a rca universal remote. my tv is curtismathes. I changed batteries. And now it does not work. I do not have the manual anymore. How do I program it. Plus there is no code button. Remote is 311w
SOURCE: code button
SOURCE: No Code Search button
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
SOURCE: where is the code search button on the rca univ. remote, rcr311w?
You can download the manual at the following link.
It is kind of a big file, so it may take a while.
http://www.retrevo.com/support/RCA-RCR311W-Universal-Remotes-manual/id/402ci571/t/2/
Just click on the get manual and then download.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
..........004, 006, 012, 023
..........024, 025, 026, 027, 028, 029
..........030, 031, 032, 033, 034, 035
..........036, 037, 038, 039, 041, 042
..........043, 044, 046, 047, 123, 124
162, 171, 177, 179, 191, 196, 208
1. Manually turn on the TV.
Find the three digit code for your TV in
the code list below.
2. Press and hold the CODE SEARCH
button until the INDICATOR LIGHT
lights, then release the CODE SEARCH
button.
3. Press and release the TV button (The
INDICATOR LIGHT will blink then
remain lit).
4. Enter the code using the Number
Buttons.
After your code is entered, the
INDICATOR LIGHT will turn off. If the
code is not valid, the INDICATOR
LIGHT will blink. Check the code list
and repeat process.
5. Aim the remote at your TV and press
the ON•OFF button. Your TV should
turn off.
Note: If your TV does not respond, try all the
codes for your brand. If the codes do not
work, or your brand is not listed, try the Code
Search method on page 16.
6. With your TV on, press CH+ (CHANNEL
UP) If the TV responds, no further
programming is required.
OK
