Prompt set spa #JL017108 does not heat up as keep getting error message E6 and keeps beeping have to reset every time not working
SOURCE: spa wont heat up e004 message appears. what does
Thank you for posting your question here on Fixya.com. If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Error 04 is a fan failure. The draft inducer is not working or the air flow sensor the heater uses to confirm the fan is operating is not closing. Check the fan first. Is it turning on and moving air thru the unit and out the vent? If so, open the cabinet and locate the tube attached to the fan housing. Follow that to a plastic switch smaller than a baseball. Remove the tune and blow it out. If there was dirt or debris in there reassemble the tubing and try the heater again. If none of this works replace the air sensor switch.
John
SOURCE: I get a message saying Hi Lim SW when trying to
Temp control failure (thermostat) high limit is safety to prevent over heat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
hi limit switch heating unit getting too hot what type of heater are you using
