Canon PowerShot SD1000 Digital Camera Logo
Lucia Posted on May 22, 2012
I have a Canon Powershot SD1100 IS. The lens cap ring trim and cover fell off. The flaps and springs are intact and it still takes great pictures. I ordered the parts from Canon and will replace th
The lens cap ring fell off and I purchased a replacement ring and lens cap from Canon. The flaps and springs are intact and the camera still takes great pictures. How do I put the ring and cap back on? They are also sending me dual-sided tape to secure the cap/ring. Any tips since I will not be receiving instructions with the parts. Thanks!
2 Related Answers
Anonymous
  • Posted on Nov 11, 2008
SOURCE: Replacing a part on my Canon PowerShot A610 Digital Camera
is it the same Powershot A540 as well?
t00nz
CameraR
  • 4738 Answers
  • Posted on Jul 14, 2009
SOURCE: Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
How do i replace lense cover on a canon sx170 is?
Since I cannot see your pieces, I can recommend actual replacement. You can Google your camera's make/model with replace lens cover and pick from the listings. You can also go straight to Canon USA and search their store as they have replacement lens covers. I did this here for another customer as an example.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
1helpful
2answers
I have a Canon Powershot SX130 IS and there is dirt behind the first piece of glass in the lens , anyway to clean it?
You shouldn't try to clean this yourself, find a camera shop that does repair or contact Canon, they will direct you to one in your area.
But before anything you better make sure the dust has any impact on the pictures.
Where can i buy the outer ring lens cap for a sd800
try this link hopefully you will find what you are looking for http://www.darntoothysam.com/products/Canon-Powershot-SD800-Camera-Lens-Ring-Trim-Repair-Part.html
SHADOW SPOT ON CANON SD1100 DIGITAL CAMERA SCREEN THAT COMES OUT ON PICTURES
The spot is actually on your camera lens. Try taking the battery out while you are in the shooting mode(lens extended) then clean the lens with a lens cleaner and that should solve your problem.
1helpful
Canon Powershot; "lense error restart camera" Cannot take pictures due to error. Lense seems to work OK mechanically on start up but has an internal issue causing error.
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Lens error canon powershot sd1100 is
Apparently, you missed some sand and it just took a while to work its evil way into the works of your camera.
I bought a canon sd1100 a year ago. It used to take great pictures. One month ago all pictures taken have been grainy. Do you know why>?
Could be that ISO settings were accidentally changed. The main annoyances with high ISO setting are the noisy (grainy as you say) images. Check the iso settings if you are shooting in modes other than automatic shooting.
1helpful
1helpful
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
1helpful
Canon A710 IS Automatic Lens Cover Assembly
I would not try to fix that lens cover issue. I would call Canon and send in for service or upgrade to another camera through their Canon Loyalty program.
Deep discounts!
You should be able to set the resolution by hitting function set, going to the bottom left corner and choosing another resolution. I'm not sure if this helps, but it is true that if you set resolution lower, you will not get the quality if trying to make large print.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
