Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Marie Blankenship Posted on May 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Has no power ,won't come on.
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on May 22, 2012
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718585
Points
48227
Follow power cord (set unplugged) to power board and the glass fuse there--check it first.
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
2000 model Hyundai lantra immobilizer won't start
un hook your battery for 15 minutes then retry to start
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
1helpful
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
1990 Accord electric windows won't close
If you own a Honda Accord, you know they rarely give any trouble. ... My 1995 Honda Accord Window Won't Close ... are a bundle of complicated electronics, lots of wiring and more computing power than the average computer from 1990. That ...
http://www.ehow.com/how_4520901_fix-power-windows-honda-accord.html
Read more: 1990 honda accord electric windows won't close ' eHow.com http://www.ehow.com/search.html?s=1990+honda+accord+electric+windows+won%27t+close+&skin=corporate&t=all#ixzz1kZmevV9g
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
2answers
I have no power to several fuses on 01 ford expedition
Check in the high amp fuse box under the hood as one of those fuses may be blown causing no power to several accessories.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
