I am using the correct memory but the system will not recognize but 256mb. I have 2gb. Why it will not recognize the 2gb of memory?
Unless only one 256-MB memory module is
installed, the modules must be installed in identical pairs. If you want
512MB total, you will need to populate by using two identical 256MB
modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type;
PC3200 ECC DDR SDRAM DIMMs
SOURCE: PowerEdge Server won't boot after memory upgrade
if you really need the BIOS update. you need a working PC to download the BIOS and unzip it to a CD. install it, since the PC do see the CD, you may have do some maneuver to ge the BIOS installed.
SOURCE: PowerEdge 1750 can not recognize the Local Harddrive
If you are using a mother board scsi raid on the Power Edge 1750 it should tell you in the start up what version 4D 4Sc extra
here is a link to Dell's down load for the driver
http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R106088&formatcnt=2&libid=0&fileid=136959
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
SOURCE: the problem is: system memory limited to 256Mb and
From BIOS, change
Os instalation mode to OFF
