SOURCE: how to fix reverse lights on a 88 chevy truck
not a plug , though kinda looks like one , but a neutral safety switch at the transmission (follow the wire to side of trans case)
SOURCE: 1991 chevy silverado lost reverse
just have someone look at it. like aamco or someone that does a free diagnostic. the tranny will probably have to be rebuilt.
SOURCE: 2000 chevrolet tahoe - can't put the gear stick in
It sounds to me as if the cable isnt adjusted properly. I would check with the shop that put the tranny in and see if they could check the adjustment on the cable, more than likely when they put in the new trans they didnt bother to adjust the cable for the replacement transmission
SOURCE: 1995 Chevy S10 Blazer will not go into park.
theres a shift cable if its floor model,linkage for column model.
SOURCE: 91 cavalier manual trans....stuck in reverse
You need to remove top off gearbox and with a pry bar or screw driver pull the selector back into neutral Your gearlever has popped out of selector Gearbox does not need to be removed
Its the original tranny its just the lockout lever wont lock
