Need a code for emerson ewc13d4 tv/dvd player have direct tv cannot program sound on volume to direct to their romote. chris
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
