Question about Crown XLS 602 2-Channel Amplifier
Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
  • Bhekie Ndlangamandla
    Bhekie Ndlangamandla May 21, 2012
    The is a audio signal in the amp but no output, when touch the pcb there's a click on the speakers
    New Friend:
    Problem Solver:
  • 8 Answers
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
Posted on May 21, 2012
6ya staff
SOURCE:
I have a crown xls602 with no audio. Speaker and power relays activates normally, signal leds palpitates with input but no sound. Appreciate any help. Thank ou.
- Use your favourite search engine (Webcrawler is dandy) and type your question/info into it.
- SEARCH ENGINES ARE YOUR FRIEND!!! Type in keywords and check the results.
- I'm not an expert but it almost sounds like maybe a speaker relay or whatever on the amp has bailed out.
Good Luck :)
R
Feb 13, 2015 | Crown XLS 602 2-Channel Amplifier
Crown XLS 602 power amp: Where inside is the fuse so I can replace it?
Hi Tom,
The fuse you may be referring from the power supply is not
used(none) instead a CB1 or circuit breaker is installed.
These breaker is in series with the power transformer ( trace it).
Disconnect the AC outputs of the power transformer when trying to
reset.( of course with the unit unplugged ).
Measure the output AC voltages, if it is OK
Be happy partially!
Next would be.....
Check for possible shorts on the Positive and Negative Supply
rails to ground or speaker out, for what might have caused the
breaker to tripped.
And these wont be easy troubleshooting , Good luck!!
thanks for choosing Fixya for assistance.
Dec 01, 2012 | Crown XLS 602 2-Channel Amplifier
Crown XLS 602 Amplifier - Channels sound different
you are riight there exist several amps like that they having different frequency on each side i supose its not properly made like that or better they wanted a pasty sound on one side and a thin on the other many times it happened to me - in older days specially lots of european amps the solution is a equalizer on the front and equilze it smoth how u want it
Apr 15, 2012 | Crown XLS 602 2-Channel Amplifier
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
I have a crown 602 channel 2 shows signal coming in, but no volume comes out. Yet when its bridge it seems to put out more power than just one chanel. Not sure where to start looking into the #2 channel...
Common problem. Power transistor in channel#2 is weak or out completely.
Bridging converts from 2 channel(stereo) to mono and you are are useing both channels in series to effectivley double your output.
Oct 04, 2010 | Crown XLS 602 2-Channel Amplifier
No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
Mar 31, 2010 | Crown XLS 602 2-Channel Amplifier
There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
Mar 04, 2010 | Crown XLS 602 2-Channel Amplifier
Left channel not operating on crown xls 602
Every time i have this prob i've blown that channel. In my case i,ve had dodgy connections to my speakers and if it is operating with high voltage rails they don't take much to blow.
Take off cover and you will no doubt find fuses somewhere blown. If it has come from speakers you prob done the amp but if not you might be lucky and just have to replace a single fuse or so.Good luck,Paul
Feb 22, 2010 | Crown XLS 602 2-Channel Amplifier
The fault light immediately comes on my Crown XLS 602 power amp immediately upon turning it on. It will not go out?
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
Aug 04, 2009 | Crown XLS 602 2-Channel Amplifier
Crown XLS 602 2-Channel Amplifier Logo
418 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
