From the symptoms, it could be a faulty keyboard -
First though, are you pressing the F2 key soon enough?
I'd turn on the notebook and then start pressing the F2 key repeatedly.
If that fails, I'd borrow an external USB keyboard to test it with first and see if it does the same thing....
Often, if the keyboard has had something spilt in it, or it has come loose, of just failed, the keyboard will not respond to any input.
If, under windows, the keyboard works fine, then that may not be the issue... if it fails under windows, you'll probably need to replace the keyboard - usually pretty easy and cheap enough to do.
"the screen becomes dark" - too dark to see? or just dimmer, as if you took out the battery charger?
if you cannot see it at all, or just barely see it - the screen inverter may have gone, or the backlight in the lcd panel, or the cable from the mainboard to the inverter...
If you are still having trouble, feel free to provide some more info re describing the dark screen issue...
Hope this info helps.
SOURCE: BIOS PASSWORD
Taking out the battery does not work anymore. The bios password is now held in an electric erasable read only memory chip AKA (EEPROM). Its a little labor intensive process to erase this chip and I am not going to go into it here. But if you rate this fixya and post an E-mail address where I can send you contact info I will send you the info you are seeking and teach you.
George
SOURCE: how to disable sata on sony vaio vgn nr 110e
For information on how to install XP (without using a floppy which has the SATA driver) on a SATA drive go to this WEB site :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
SOURCE: i have toshiba satellite L305d-s5934, Blue screen
Seems you have a BAD BIOS, it controls all peripherals of your laptop that's why it can't detect or goes BLUE SCREEN before it enters BIOS. Check what BIOS VERSION you have and update it using EMERGENCY RECOVERY DISK. Search Google for your BIOS info.
SOURCE: Acer 3000 Series Laptop Splash screen does not
It sounds like the Acer logo has been turned off in the bios settings. As soon as you hit the power button, start tapping the F2 key until you see the test appear "entering setup". Once you are in the BIOS, look for the Logo settings as far as being visible during Boot up. I've seen this setting on other systems so I am thinking the Acer should be similiar.
