SOURCE: Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for
input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
SOURCE: sharp mx 2700n how to go SP mode and i get error code h5.01
Use SIM14 to
cancel the trouble.
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
I have changed drums, developers, transfer belt 1&2 but nothing changed
