I need the code for the tv daewoo and dvd toshiba
SOURCE: I need a code for a Toshiba TV remote and a Cyberhome DVD Player
Try searching for your code. If it is not listed in the manual. Here are the instructions to search for your codes:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Here is your manual:
http://www.ofausa.com/remote_manual/CTGAE3P%203021%20anual%20booklet.pdf
SOURCE: code for my tv using my one for all remote
i lost the codes to my phillip magnavox can u provide me with those codes urc 3021
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and
allow power on and off while in TV mode. This worked for me on the RC32
remote control.
SOURCE: codes for daewoo
There should be an instruction manual online at One for All.com. You have a learning remote and it should detect the codes for you by the indicated flashing lights when following the instruction set for TV.
