SOURCE: I just received a brand
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
It took several minuets for my new remote to register anything. I just assumed they came completely dead and it takes a while to get to the point where it will function.
SOURCE: how to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
SOURCE: need viper 7752v owners manual
Here is a quick manual for the setup options and pairing that I put together
.http://www.the12volt.com/installbay/file.asp?ID=1171
