HTC Freestyle Smartphone Logo
Posted on May 20, 2012
My htc freestyle keeps changing the order of my texts. it puts all texts ive sent on top and ones received on the bottom, how do i change it?
It groups all of my sent text together in the order ive sent them and all the texts ive received in order together. as apposed to the traditional this is what you sent this was said persons response
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
264
Points
Try going to menu, settings, date & time, and make sure the information is correct where it says "set date" and "set time." if either is wrong, enter the correct information. that should fix it.
what happened is your phone thought you were sending a message earlier or later in time than you actually were, while whoever you're texting was sending messages on time. soooo all of your messages end up clustering at the top or bottom depending on if your phone's date & time is set early or late.
2 Related Answers
billa vimal
vimal raj
  • 64 Answers
  • Posted on Sep 06, 2009
SOURCE: vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
Anonymous
  • Posted on Jan 14, 2010
SOURCE: I DONT KNOW HOW TO CHANGE THE TEXT MESSAGE
go to messages first, then settings and you can change it.
1helpful
I can not acess my email. It says I have put in a wrong password. I tried using password sent to my phone and ths\at does not work either.
When you sign up for a free Yahoo! account, you gain access to the extensive features of the Yahoo! community and receive a free email account.
As with any account, it is a wise idea to change your Yahoo! password a few times a year in order to ensure its security.
Knowing where to go in Yahoo! to change your password will allow you to do it quickly.
Sign into your Yahoo! email account.
Click on your Yahoo! name at the top of the webpage to access drop-down options.
Select the "Profile" option.
Your account page will open.
Place your cursor over "Account Info" in the toolbar.
Options will again drop down.
Click "Change Password."
Type in your current Yahoo! email password in the first text box.
Enter your new Yahoo! password in the lower two text boxes.
Click "Save."
Your Yahoo! password is now changed.
Aug 16, 2013 • Yahoo Mail
My htc freestyle will not show my sent messages
go to your menu, check messages, then look for sent.
5helpful
2answers
My htc freestyle will not receive incoming text messages
I had to got to message and select deleted messages and delete them. If you delete them they are still there until you clear them. I didn't know this.
2answers
User manual
For the english manual click the following link:
http://dl4.htc.com/web_materials/Manual/HTC_Touch_Cruise/HTC_Cruise_English_Manual.pdf
If you want other versions or languages please see the downloads page for your HTC Cruise phone at http://www.htc.com/www/userguide.aspx?p_id=59
My phone randomly stopped sorting my texts properly
is that face book texts or actual texts? as for the time stamp. my carrier gets it wrong quite often. thats usually when the signal is very weak when they're sent or received.
My text messages are not sent out until days later, I have the Request Delivery report option turned on and still no text being sent out. I receive text with no problem.
check out the sms centre number,turn of reply via same centre,make the validity as maximum and put the message type as text,switch off and restart your mobile.
Problem receiving and sending texts on HTC P3600 PDA
Check your message center number. Contact your service provider. If nothing helps, reset your phone to factory settings
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
