SOURCE: Changing company message on KX-T7730
hi there! can you please help me? how can I create/record a voice message? Thank you.
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: cacelling forward
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
SOURCE: Panasonic KX-T7730 Diverting Calls back
If you set call forward all calls then lift your handset press the FWD/DND button, dial 0 , you should get a tone, then hang up. If you set Follow Me then dial 8 and your extension number instead of the 0 . Good Luck. ....Mike
Somewhere in all of this text, maybe you can find the PROGRAMMING manual. Look for 3 digit codes numbered 405-408 or something like it.
